Reset / Clear Graphics overrides API
I am struggling in search for solution for some time. Can someone help me or guide me to post which explains this: how can i reset graphicoverrides by element if i set them out like this?
ElementId ID = RB.Id;
OverrideGraphicSettings orGsty= new OverrideGraphicSettings();
 foreach (FillPatternElement FP in FillPattern)
                        if (FP.Name == "Solid fill")
                            orGsty.SetProjectionFillPatternId(FP.Id);
using (Transaction t = new Transaction(doc, "Set Element Override"))
                            t.Start();
                            doc.ActiveView.SetElementOverrides(ID, orGsty);
                            t.Commit();
How can i reset overrides trough API?
Thanks in advance!
matthew_taylor
Hi @Anonymous,
You can just pass in a new OverrideGraphicSettings without any modifications.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Hello @matthew_taylor,
easy and effective 🙂 that is solution! Thank you.
"Why make things simple when one can make them complicated?"
