- Mute
- Permalink
- Report
I have an API that will update parameters in both 3D families and 2D families. Some of those parameters are also included in Text Notes in Details and General Notes. I can replace the text in the the Text Notes but the pieces of the the Text Note that is underline is now not underlined. It seems my only options are either to underline the entire Text Note or none of it.
Example Text.
[C] FLAT PANEL DISPLAY BOX J6(N2,P2)
FSR PWB-250 WALL BOX. ASSEMBLY COMES STANDARD WITH QTY-1 LOW VOLTAGE ENTRY BOX. ORDER ADDITIONAL LOW VOLTAGE ENTRY BOX FSR PART NO. PWB-250-AVBB OR RACO 565 (SEE DETAIL 4/AV401 FOR APPROPRIATE LOCATIONS), SEE CONDUIT RISER DRAWINGS FOR REQUIRED QUANTITY. TERMINATE CONDUITS TO UPPER OR LOWER LOW-VOLTAGE ENTRY BOXES. (P2) DUPLEX RECEPTACLE INSTALLED IN PASS-THRU ENCLOSURE, AND (N2) INSTALLED IN LOWER ENTRY BOX WITH A SINGLE GANG BACK BOX (NOT INCLUDED WITH PWB-250). AT EACH PWB-250 LOCATION SUPPLY A FLAT PANEL DISPLAY MOUNT SEE DETAIL 5/AV401.
My API would replace the numbers J6, N2, or P2. You can see they are both underlined and not underlined within the Text Note.
Does anyone know how I can keep the fomatting?
