Renaming Walls Names in Revit
cbengaaa
Observer Observer
cbengaaa
Observer
Observer
Hello everyone, I am a Civil Engineer who just started to learn programming and RevitAPI
I may be still a bit confused about Revit hierarchy system of Elements (Would be nice if a someone refers me a good resource to understand it)
I've made a similar plugin for Columns and it worked [Check Photo], but when I tried to do so with Walls I get errors [Check Photo of Error]
I wrote down my code
NOTE: All Application and Document is pre-defined and References attached
When I tried to debug the process the Exception appears to be in line: 20
Thank you in advance
 TransactionGroup caseWall = new TransactionGroup(doc, "Renaming Wall Types");
     caseWall.Start();
     FilteredElementCollector wallCollector = new FilteredElementCollector(doc);
     ElementCategoryFilter wall = new ElementCategoryFilter(BuiltInCategory.OST_Walls);
     List<Element> listofwalls = wallCollector.OfClass(typeof(Wall)).WherePasses(wall).ToList();
     List<Wall> listofwallsWalls = new List<Wall>();
     Transaction trnWall = new Transaction(doc, "Renaming Walls");
         trnWall.Start();
         foreach (Element wt in listofwalls)
             try
                 if ((wt as Wall).StructuralUsage.ToString() == "Bearing" && (wt as WallType).Kind.ToString() == "Basic")
                     double width = (wt as Wall).Width * 0.30; //Convert to Meters
                     string actualName = wt.Name;
                     string newName;
                     newName = actualName + $"{(width)}";
                 else
                     gm.ShowTask($"WallId Failed: {(wt as Wall).Id}\n Wall Name Failed: {(wt as Wall).Name} ");
             catch (Exception ex)
                 gm.ShowTask(ex.Message);
         trnWall.Commit();
     caseWall.Assimilate();
Mohamed_Arshad
HI @cbengaaa
    To rename the wall you have choose the WallType.Name, I have modified your code to achieve the functionality. Kindly refer the below code
Reference Code:
                caseWall.Start();
                    trnWall.Start();
                        Wall _wall = wt as Wall; //Converting Element to Wall
                        try
                            if (_wall.StructuralUsage==StructuralWallUsage.Bearing && _wall.WallType.Kind == WallKind.Basic) //Using Enum for Checking dont't convert to string
                                double width = _wall.Width / 3.2808399; //Convert to Meters (To Convert feet to meter need to divide 3.2808399)
                                string newName;
                                newName = actualName + $"({width})"; //Brackets should be outside the curlybraces
                                //Set New Name to Wall Type
                                _wall.WallType.Name = newName;
                            else
                    trnWall.Commit();
Reference Image:
Note : Use Math.Round to control the precision.
Links to Learn Revit API
https://spiderinnet.typepad.com/
https://thebuildingcoder.typepad.com/
https://www.autodesk.com/autodesk-university/class/Revit-Programming-Beginners-Easily-Access-Revit-A...
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7I2bC1zUr4VjJ3U31uM66K.html
Video Tutorials
https://youtube.com/playlist?list=PLlyMZ5IcKcci1TvB4qM9S8J-RKp0DhVWO&si=N_G9KYKvXjA3oxLP
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
cbengaaa
Observer
Observer
thank you so much, you are the best!
I guess I still need a little dive into Revit API to get it correctly.
