Removing dimension leader not visible - only after reselection or reopening mode
12:11 AM
- Mute
- Permalink
- Report
I am trying to remove the dimenionleader using the API. I have set value of builtinparameter 'DIM_LEADER' to '0' and that removes the dimension leader. The removal however is only visible after manually selecting / unselecting the changed dimension (or closing / opening the model al together).
Is there a way to 'regenerate' the dimension (doc.regenerate does not seem to do it)?
regards,
Raymond
