Refresh projectbrowser (after renaming sheetnumber)
c_hanschen
Message 1 of 22
c_hanschen
After renaming SheetNumber with Revit API, the project browser still shows the old name.
When selecting the Sheet, the new SheetNumber is shown in the properties panel, but not in the projectbrowser.
When remaing 100 sheets with Revit API, I only need to edit 1 manually for all sheets te be show properly in de projectbrowser.
HOW TO REFRESH THE PROJECTBROWSER BY REVIT API?
I have tried Class 'BrowserOrganization', but is seems only to be able to read stuff, not to change the browserorganisation.
please help.
greetings from the Netherlands,
Chris Hanschen, LKSVDD architecten BV. (Hengelo)
Replies (21)
Message 21 of 22
c_hanschen
@michael-coffey
Yes, this is an old post, it is solved in later versions of Revit, in think in R2020 en R2021 this is also solved.
Chris Hanschen
LKSVDD architecten, The Netherlands
Message 22 of 22
michael-coffey
I'm having the same issue in a 2022 wpf app I'm working on though.  Adding the project browser show command does help.  But it flashes on the screen.
