Reference of a Wall Face
Message 1 of 10
Hi there,
After extracting a Face Class object from a wall, it seems that the reference property of a Face returns null.
Actually I am trying to use the resulting Reference in creating a DivisionSurface Class object. Isn't it possible?
FR=Face.Reference
DivSur=DB.DividedSurface.Create(doc, FR)
Replies (9)
Message 2 of 10
jeremytammik
To access the wall face, I assume that you call the wall's Geometry property:
https://www.revitapidocs.com/2020/d8a55a5b-2a69-d5ab-3e1f-6cf1ee43c8ec.htm
In doing so, you need to supply Options. In the options you provide, you need to specify ComputeReferences = true:
https://www.revitapidocs.com/2020/d7da6de4-74a9-60e2-826f-698a5730d0a8.htm
Determines whether or not references to geometric objects are computed.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 10
Hi thanks
Actually I have set the ComputeReferences to True, yet, it still does not work. A window pops upon executing the command. It asks me to delete the element and once I let it delete another window pops up. Screenshots are attached.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            Reference pickObj = uidoc.Selection.PickObject(ObjectType.Element);
            try
                if (pickObj != null)
                    Options opt = new Options();
                    opt.ComputeReferences = true;
                    ElementId elemid = pickObj.ElementId;
                    Element elemt = doc.GetElement(elemid);
                    GeometryElement geo = elemt.get_Geometry(opt);
                    foreach (Solid sol in geo)
                        Solid geSolid = sol as Solid;
                        FaceArray fcA = geSolid.Faces;
                        foreach(Face f in fcA)
                            Transaction trans = new Transaction(doc, "DivideSurface");
                            trans.Start();
                            Reference fr = f.Reference;
                            DividedSurface ds = DividedSurface.Create(doc, fr);
                            trans.Commit();
                return Result.Succeeded;
            catch(Exception e)
                message = e.Message;
                return Result.Failed;
Message 4 of 10
jeremytammik
You code is very badly structured.
Refactor it.
  • First, pick your element.
  • Secondly, iterate over the geometry and extract the data you need, e.g., references.
  • Third, start a transaction and do the job
These three steps can and should be cleanly separated!
Jeremy Tammik
The Building Coder
Message 5 of 10
zhongding_cui
Encountering similar problem where the
face.Reference == null
despite the:
when capturing the face from the GeometryElement. The Face I am working with is a valid HermiteFace.
Is this a known bug? Can we ask for a bug fix ticket on it?
Message 6 of 10
zhongding_cui
When defining the option, I tried:
Also tried:
Options opt2 = app.Application.Create.NewGeometryOptions();
Neither of them returns a valid reference for the HermiteFace inside of
Are we missing something other than the ComputeReference = true setting?
Message 7 of 10
Moustafa_K
you need to set computeReferences to True
not sure if this post would also be in a help in your case
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 8 of 10
jeremy_tammik
HermiteFace... interesting. What do you want the reference for? Dimensioning? If so, can you create the dimensioning you have in mind manually through the end user interface? Maybe there are limitations on references to HermiteFace objects. Maybe there is something else less complex and more stable in your model geometry that you can use as a reference instead.
Message 9 of 10
zhongding_cui
Yeah this is exactly what I am trying to figure out by posting here. We are trying to use Revit on some unconventional projects, so the use of HermiteFace is inevitable.
Any further suggestions Jeremy? Thanks a lot.
Message 10 of 10
jeremy_tammik
Yes, definitely. This forum is for discussing programming issues. The API is more or less a wrapper around the UI functionality. To discuss unconventional projects, I recommend solving all questions manually through the end user interface first, before trying to address them programmatically. The best place to discuss optimal workflow and best practice issues in the UI is generally the larger and more generic architectural forum.
