modifying furniture system (standing desk L angled to a regular L shape)
modifying furniture system (standing desk L angled to a regular L rectangle)
this is really annoying, this has happened with other components as well where i cant make simple modifications of the shape and when i load it into the project it just stays the same as it was before i edited it in family editor. ive tried everything, different setting in the project browser, loading w/ & w/o replacing parameters, renaming and saving it under a different name, ive deleted geometry from it (the desktop in this instance to troubleshoot where the issue is coming from but even then when i load it into the project it looks the exact same as before i tried to update the geometry!!!! i need this desk to update how ive modified it!!! if i deleted the desktop from the frame what do i need to do in the family editor so that when i load it into the project it looks like how i edited it in the family editor?? if im able to do that i think i should be able to modify it how i really want it to be (trying to remove the angled/sloped end)???
thank you,
Gaby.
jeremytammik
Dear Gaby,
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
