Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Reference File Unload Without Input
1 REPLY 1
274 Views, 1 Reply
I'm having an issue with Revit reference files unloading from a project without user input. The file locations have not changed. On attempting to reload the files, which appear in the reference file manager as still loaded, an error is generated that the reference files are loaded into another open project. This is unusual in that only one file was open on the workstation.
The problem resolves itself on closing and reopening the project. This consumes too much time as Revit continues to lose money for us. Why are we paying autodesk to take money out of our pockets.?
1 REPLY 1
jeremytammik
Dear Tbransom,
Thank you for your query.
Unfortunately, I cannot say anything helpful about it here in this forum.
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
