Rectangle Lines
Rectangle Lines
Rectangle Lines
Any simple method to check whether a polyline or (set of 4 lines) is a rectangle?
Any code simpler than this?
                                bool blnRectangle = false;
                                if (polyline.NumberOfCoordinates == 5) {
                                    if (PointsAreEqual(polyline.GetCoordinate(0), polyline.GetCoordinate(4))) {
                                        Line line1 = Line.CreateBound(polyline.GetCoordinate(0), polyline.GetCoordinate(1));
                                        Line line2 = Line.CreateBound(polyline.GetCoordinate(1), polyline.GetCoordinate(2));
                                        Line line3 = Line.CreateBound(polyline.GetCoordinate(2), polyline.GetCoordinate(3));
                                        Line line4 = Line.CreateBound(polyline.GetCoordinate(3), polyline.GetCoordinate(4));
                                        if (DoubleValuesAreEqual(line1.Length,line3.Length) && DoubleValuesAreEqual(line2.Length, line4.Length)) {
                                            double dblRad = line1.Direction.AngleTo(line2.Direction)/Math.PI;
                                            if (DoubleValuesAreEqual(dblRad, 0.5))
                                                blnRectangle = true;
aignatovich
Hi!
You can create curveloop from your lines, than perform a check:
curveloop.HasPlane() && curveloop.IsRectangular(curveloop.GetPlane())
The method is simple. Thanks.
Anyway to check lines is a curve loop is not so simple, right? Smiley Sad
aignatovich
Yep, but It depends on your task, may be some factors will help you.
Polyline coordinates are subsequent, so they form the curveloop, but it can be open, check curveloop.IsOpen() also
