Event handler respond with OK after called Purge button
Shai.Nguyen
Message 1 of 9
Shai.Nguyen
My idea is same as: https://forums.autodesk.com/t5/revit-api-forum/purge-unused/m-p/7170536/highlight/true#M23707
I want to clean up the revit file before sent it to client. One of those is purge at least 3 times. How can I write an Event that respond with OK?
Thank you in advanced, your solution is appriciated.
Replies (8)
Message 2 of 9
jeremytammik
You can look at the JtClicker windows form clicker app:
http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
https://github.com/jeremytammik/JtClicker
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
Shai.Nguyen
Thanks Jeremy, I will take a look
Message 4 of 9
RPTHOMAS108
Basic example:
Imports Autodesk.Revit.UI
Imports Autodesk.Revit.DB
Public Class MultiPurgeExampleClass
    Private Shared RunCount As Integer = 0
    Private IntApp As Autodesk.Revit.UI.UIApplication = Nothing
    Private IntDoc As Document = Nothing
    Public Sub Run()
        If IntDoc Is Nothing Then Exit Sub Else
        'Code upto this point your choice (part of IExternalCommand)
        Try
            AddHandler IntApp.DialogBoxShowing, AddressOf ReturnOKResult
        Catch ex As Exception
        End Try
        RunCount = 0
        ReRun()
    End Sub
    Public Sub New(ByVal CMD As Autodesk.Revit.UI.ExternalCommandData, _
                           ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet)
        IntApp = CMD.Application
        If IntApp.ActiveUIDocument Is Nothing Then Exit Sub Else
        IntDoc = IntApp.ActiveUIDocument.Document
    End Sub
    Private Sub ReRun()
        RunCount += 1
        Dim CDMID As Autodesk.Revit.UI.RevitCommandId = _
        Autodesk.Revit.UI.RevitCommandId.LookupPostableCommandId(PostableCommand.PurgeUnused)
        IntApp.PostCommand(CDMID)
    End Sub
    Private Sub ReturnOKResult(s As Object, e As Autodesk.Revit.UI.Events.DialogBoxShowingEventArgs)
        e.OverrideResult(MsgBoxResult.Ok)
        If RunCount < 5 Then
            ReRun()
        Else
            RunCount = 0
            Try
                RemoveHandler IntApp.DialogBoxShowing, AddressOf ReturnOKResult
            End Try
            MsgBox("Multi purge complete.", Title:="Information")
    End Sub
End Class
Message 5 of 9
Shai.Nguyen
Hi Thomas, I'm using C#. I wondering if you can translate this code to C# language. I'll very appriciate
Message 6 of 9
RPTHOMAS108
Create a new instance of MultiPurgeExample and then start it with Run.
C#
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
public class MultiPurgeExampleClass
    private static int RunCount = 0;
    private Autodesk.Revit.UI.UIApplication IntApp = null;
    private Document IntDoc = null;
    public void Run()
        if (IntDoc == null)
            return;
        //Code upto this point your choice (part of IExternalCommand)
        try
            IntApp.DialogBoxShowing += ReturnOKResult;
        catch (Exception ex)
        RunCount = 0;
        ReRun();
    public MultiPurgeExampleClass(Autodesk.Revit.UI.ExternalCommandData CMD, ref string message, Autodesk.Revit.DB.ElementSet elements)
        IntApp = CMD.Application;
        if (IntApp.ActiveUIDocument == null)
            return;
        IntDoc = IntApp.ActiveUIDocument.Document;
    private void ReRun()
        RunCount += 1;
        Autodesk.Revit.UI.RevitCommandId CDMID = Autodesk.Revit.UI.RevitCommandId.LookupPostableCommandId(PostableCommand.PurgeUnused);
        IntApp.PostCommand(CDMID);
    private void ReturnOKResult(object s, Autodesk.Revit.UI.Events.DialogBoxShowingEventArgs e)
        e.OverrideResult(MsgBoxResult.Ok);
        if (RunCount < 5)
            ReRun();
        else
            RunCount = 0;
            try
                IntApp.DialogBoxShowing -= ReturnOKResult;
            Interaction.MsgBox("Multi purge complete.", Title: "Information");
Message 7 of 9
Shai.Nguyen
Hi Thomas, why I have an error here?
Message 8 of 9
RPTHOMAS108
It is a visual basic namespace that is missing but you don't need it, bad conversion from VB on my part:
Use instead TaskDialogResult.OK for the first error (it is just a value of 1)
Use instead a TaskDialog.Show for the second error (if you care about being told the task is complete)
Message 9 of 9
Shai.Nguyen
Thanks again. You are fast like a thunder storm
