Rebar TAG Selection
Rebar TAG Selection
stefano.cartaKGT96
Rebar TAG Selection
stefano.cartaKGT96
Hi..
I am trying to create a collection of all MultiReferenceAnnotations like the tag with 139
With Revitlookup I found that the id  of this annotation is -2000970
I tried the code below but the collection is nothing.
If I try to collect rebar tags (-2009020) like tag with 174, with the some code, work fine
Where I wrong?
Dim tagColl As List(Of Element) = New FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(-2000970).Where(Function(x) TypeOf x Is IndependentTag).ToList()
architect.bim
Hi!
OfCategory method requires BuiltInCategory enumeration. In your case:
OfCategory(BuiltInCategory.OST_MultiReferenceAnnotations)
Maxim Stepannikov | Architect, BIM Manager, Instructor
stefano.cartaKGT96
Hi Maxim
Thanks for your quickly replay..
I will try it tomorrow...
stefano.cartaKGT96
Hi..
I modified my code with "BuiltInCategory.OST_MultiReferenceAnnotations" but tagcoll is empty
Dim tavTAG As Boolean = Revit.ED_Utility.ElementIsTagged1(doc, ele, (BuiltInCategory.OST_MultiReferenceAnnotations), (BuiltInCategory.OST_Rebar))
  Public Shared Function ElementIsTagged1(ByVal doc As Document, ByVal ele As Element, ByVal eleTag As BuiltInCategory, ByVal eleElements As BuiltInCategory) As Boolean
            Dim tagColl As List(Of Element) = New FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(eleTag).Where(Function(x) TypeOf x Is IndependentTag).ToList()
            Dim eleColl As List(Of Element) = New FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(eleElements).ToList()
            Dim ids As List(Of ElementId) = New List(Of ElementId)()
            For Each e As Element In tagColl
                Dim tag As IndependentTag = TryCast(e, IndependentTag)
                Dim id As ElementId = tag.TaggedLocalElementId
                Dim aux1 As Integer = tag.TaggedLocalElementId.IntegerValue
                Dim aux2 As Boolean = ids.Contains(tag.TaggedLocalElementId)
                If (tag.TaggedLocalElementId.IntegerValue <> -1) AndAlso (ids.Contains(tag.TaggedLocalElementId) = False) Then
                    ids.Add(tag.TaggedLocalElementId)
            Next
            Dim uniqueIds As List(Of ElementId) = ids.Distinct().ToList()
            Dim eleIds As List(Of ElementId) = New List(Of ElementId)()
            For Each e As Element In eleColl
                eleIds.Add(e.Id)
            Next
            Dim idEleTag As List(Of ElementId) = New List(Of ElementId)()
            For Each id As ElementId In eleIds
                If uniqueIds.Contains(id) Then
                    idEleTag.Add(id)
            Next
            If idEleTag.Contains(ele.Id) Then
                Return True
            Else
                Return False
        End Function
architect.bim
Sorry, maybe I misunderstand the problem but in fact if you need to select all multireference annotations on view you can use either OfClass or OfCategory method. In both cases you get the same results:
# Python code
tags_of_class = FilteredElementCollector(doc, doc.ActiveView.Id) \
    .OfClass(DB.MultiReferenceAnnotation)
tags_of_category = FilteredElementCollector(doc, doc.ActiveView.Id) \
    .OfCategory(DB.BuiltInCategory.OST_MultiReferenceAnnotations) \
    .WhereElementIsNotElementType()
The elements you try to get do not belong to IndependendTag class. I think in your code the problem is there.
