Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Rebar shape length parameters inverted when creating rebar from curves
purzua5SCRP
purzua5SCRP
I’m having problems when creating rebars using the API (although I think the same issue also happens when using the Revit UI).
I have a custom Rebar Shape family named “TEST2”:
To create a rebar in the following floor, I define three points, which define two curves. Hoping curve0 gets length A and curve1 length B:
This is the code:
After execution, I get this rebar. As you can see, the parameters are inverted: I expected the horizontal bar to have length A and the vertical bar to have length B.
I already tried editing the Rebar Shape family so that length A > length B, but the result is the same.
Now, if I edit the Rebar Shape family (toggle Shape Orientation):
And in the code I define the points like this:
I get this rebar. Now the first curve (curve0) gets the correct length parameter (B)
It would be great if someone could explain the logic behind this behavior.
Should I always define the points in the Shape Orientation order?
How does Revit assign parameters to rebars created using the CreateFromCurvesAndShape method?
Thanks in advance!
purzua5SCRP
Any guidance, please? Thanks! this is Revit 2024
