Rebar placement in Revit 2023 and Revit 2024
shindeaa15
shindeaa15
Query: I am trying to place rebars manually for a Model contains Walls and Floor structures. To add Rebars following steps are followed. Can anyone guide to confirm that I am following proper steps and not missing anything.
Revit 2023:
  1. Opened Revit model and selected Level 1 View.
  2. After navigating to Level 1 View, clicked on Rebar button which is located in Structure Tab
  3. Refer below image.
  5. Clicking on Rebar button will not result anything in Revit 2023.
Revit 2024:
  1. Opened same Revit model in Revit 2024 and selected Level 1 View.
  5. Clicking on Rebar button will not results Rebar placement option as shown below.
  7. As shown in above image following same step, here I am able to place Rebar manually.
Can anyone please guide if I am missing something.
Thank you in advance.
jeremy_tammik
I assume that after our preceding conversation, you aimed to ask this in the structural forum:
Unfortunately, your post ended up back here in the API forum instead after all  🙂
