Reading informations into an IFC
SONA-ARCHITECTURE
SONA-ARCHITECTURE
I so lot of stuffs about reading IFC file  :
  1. OpenSourceReading here :https://forums.autodesk.com/t5/revit-api-forum/opensource-api-for-reading-ifc-files/m-p/6433280
  2. Using Autodesk.Revit.DB.IFC Namespace
  3. XBimToolKit
  4. etc.
I'd like to have an advice :
If I want to read informations (IFCSite coordinates, Parameters from objects, etc.) what is the mots suitable solution? If I use the Autodesk.Revit.DB.IFC Namespace, it seams to convert the IFC file into Revit model, is it real?
Many thanks for your help.
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
jeremytammik
I can answer your last question: yes, the Autodesk.Revit.DB.IFC functionality can read an IFC file and generate a placeholder RVT from that. I used that in my IfcSpaceZoneBoundaries project.
Jeremy Tammik
Developer Technical Services
The Building Coder
SONA-ARCHITECTURE
Ok, Thx Jeremy
Does the Revit.IFC.Import systematically generate an ifc.rvt model or can I just use it to read informations into the IFC without generate a Revit File?
Pierre NAVARRA
SONA-Architecture.
