第 1 条消息(共 3 条)
Reading informations into an IFC
I so lot of stuffs about reading IFC file :
- OpenSourceReading here :https://forums.autodesk.com/t5/revit-api-forum/opensource-api-for-reading-ifc-files/m-p/6433280
- Using Autodesk.Revit.DB.IFC Namespace
- XBimToolKit
- etc.
I'd like to have an advice :
If I want to read informations (IFCSite coordinates, Parameters from objects, etc.) what is the mots suitable solution? If I use the Autodesk.Revit.DB.IFC Namespace, it seams to convert the IFC file into Revit model, is it real?
Many thanks for your help.
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
SONA-Architecture.
