Reading family parameter values without an instance
adam.krug
adam.krug
Let's assume I have such family tree in my project:
Family A
   Type A1
   Type A2
   Type A3
Family B
   Type B1
   Type B2
The families are not system families (they are editable). I wan't to check what is the value of Family Parameter XYZ (let's assume it's a YesNo type parameter) of each type of these families. Can I do that without having to make an instance of each or going into EditFamily mode and looping through types? How?
jeremytammik
Dear Adam,
If you are lucky, the part atoms will give you all you need:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
adam.krug
Dear Jeremy,
This method requires having my families as .RFA files. I want to work within the project environment on families loaded in it. I'd like to avoid saving the families as external files.
jeremytammik
Dear Adam,
All the information that you can access via the API is the project environment is also interactively navigable using RevitLookup.
If you cannot access it using RevitLookup, EditFamily is the only other choice in this situation, afaik.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
adam.krug
Thanks Jeremy,
I will try RevitLookup to see how it can help.
Cheers,
Adam
