Hi All,
I am importing dwg file which has certain XRecord data attached to it.
Is there any way to read this XRecord inside revit after importing ?
Suraj
Hi All,
Suraj
Solved by jeremytammik. Go to Solution.
Yes.
You can use the AutoCAD.NET API.
You can do so from within your Revit add-in.
This requires both AutoCAD and Revit to be installed, and Revit must be running, and you must be within a valid Revit API context.:
https://thebuildingcoder.typepad.com/blog/2008/11/running-autocad-inside-revit.html
Yes.
Thanks Jeremy.
