"ImageType.Create" method causes unexpected internal error.
yongjoon4VB45
Message 1 of 10
yongjoon4VB45
I'm trying to import an image using Revit 2021 API.
from rpw import DB
image_options = DB.ImageTypeOptions("C:\\temp\\response.jpg", False, DB.ImageTypeSource.Import)
image_type = DB.ImageType.Create(doc, image_options)
However, it creates this error:
Exception : Autodesk.Revit.Exceptions.InternalException: Failed to create ImageType due to internal error.
Can someone help me understand why it's happening?
Thanks.
Replies (9)
Message 2 of 10
franciscopossetto
Hey,
You need to add a new transaction to run ImageType.Create method. Then your code should work.
Github:
https://github.com/franpossetto
Message 3 of 10
yongjoon4VB45
Hi @franciscopossetto ,
Thanks so much for the response. I probably should have included the full code snippet! I did open the transaction, but it didn't really work.. Could you comment on my code?
with db.Transaction("Import Google Maps"):
    # Import Options
    active_view = uidoc.ActiveView
    image_options.Resolution = 72
    image_placement = DB.ImagePlacementOptions(
        DB.XYZ(0, 0, 0), DB.BoxPlacement.BottomLeft
    image_instance = DB.ImageInstance.Create(
        doc, active_view, image_type.Id, image_placement
Message 4 of 10
Sean_Page
Doesn't look like you are supplying the correct info to the transaction.
trans = db.Transaction(doc,"name")
trans.Start()
##Do code
trans.Commit()
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Message 5 of 10
yongjoon4VB45
Hi @Sean_Page ,
Thank you so much for your comment! I think that was one part of the issue. However, now I get this Revit error message along with the same 'internal error' response in the console.
Could you provide any other insight here?
Thanks so much!
Message 6 of 10
Sean_Page
Is there a reason why you use "db" for the transaction and then"DB" for the image? Are they different references?
Also, active view comes from the doc, not uidoc so that could also be a problem.
Message 7 of 10
franciscopossetto
Hey,
I tested your code. I adeed the Transaction and it worked.
t = DB.Transaction(doc, 'Import from GoogleMaps')
# Import Options
    "C:\\temp\\1.jpg", False, DB.ImageTypeSource.Import
t.Start()
t.Commit()
@Sean_Page  I thought the same thing, but UIDocument has the property ActiveView as well. Both return the Active View, but from what I could read on the Remarks, they have small differences.
Github:
Message 8 of 10
Sean_Page
I think the thing here is the UIDoc.ActiveView will always be the current UI document, but that may not be the doc you want to get the active view of. I'd assume in many cases these will work the same, but they are not always the same.
https://www.revitapidocs.com/2022/b6adb74b-39af-9213-c37b-f54db76b75a3.htm
https://www.revitapidocs.com/2022/043960ac-dde4-0f45-249f-8161646a4362.htm
Message 9 of 10
franciscopossetto
Interesting, thanks for sharing!
I have found a small but very good difference between them: ActiveView on UI Document provides get and set methods unlike Document which can only provides get. Last time I needed to open or switch between views I used uiDoc.RequestViewChange(view) what basically do the same that uiDoc.ActiveView = view.
Now I wonder if there is any difference between them or if they are mostly the same.
Github:
Message 10 of 10
yongjoon4VB45
Hi @franciscopossetto @Sean_Page ,
Thanks for your brainpower on this, and I finally solved the issue.  Thanks for testing the code! I found that it's not actually the issue of the code itself, but the JPG image. I'm currently making an HTTP request from Revit to Google Maps API to bring the JPG image, and for some reason the JPG response data from GMap API is not readable in Revit API environment. Other response type such as PNG or BMP has no issue with the execution with the same code.
Maybe I should have shared the full context of the code and where the source image came from, but this is what I 've learned so far! Hope it helps you in the future when you work on something similar.
Thanks!
