I recently wrote an ExternalCommand to generate swept solid based on the location curve of a selected element. However, when a curved wall is selected, there is a exception reads:"The Curve Loop does not lie in the plane orthogonal to the projPlaneNorm". I don't know how to solve the problem and hope to get support from the community. Thank you so much!
Here is my code
[Transaction(TransactionMode.Manual)] [Regeneration(RegenerationOption.Manual)] public class GenerateSweptGeometryBasedOnLocationCurve : IExternalCommand { public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) { Document doc = commandData.Application.ActiveUIDocument.Document; Autodesk.Revit.UI.Selection.Selection sel = commandData.Application.ActiveUIDocument.Selection; Reference reference = sel.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element); Transaction trans = new Transaction(doc); Element elem = doc.GetElement(reference); trans.Start("Create solid"); LocationCurve lc = elem.Location as LocationCurve; if (lc != null) { //Create the sweep path var pathCurveLoop = new CurveLoop(); pathCurveLoop.Append(lc.Curve); Curve firstCurve = pathCurveLoop.ElementAt(0); //get the point to create a plane for the profile. XYZ xyzFirstPoint = firstCurve.GetEndPoint(0); //Create the plane Transform transform = firstCurve.ComputeDerivatives(0, true); XYZ xyzDirection = transform.BasisX; Plane profilePlane = Plane.CreateByNormalAndOrigin(xyzDirection.Normalize(), transform.Origin); //Create a profile which is a rectangle with height and width of 2000mm and 900mm double dblHeight = 2000 / 304.8; double dblWidth = 900 / 304.8; UV uvPt0 = new UV(0, 0) - new UV(dblWidth / 2, 0); UV uvPt1 = uvPt0 + new UV(dblWidth, 0); UV uvPt2 = uvPt1 + new UV(0, dblHeight); UV uvPt3 = uvPt2 - new UV(dblWidth, 0); XYZ xVec = profilePlane.XVec; XYZ yVec = profilePlane.YVec; XYZ xyzPt0 = profilePlane.Origin + profilePlane.XVec.Multiply(uvPt0.U) + profilePlane.YVec.Multiply(uvPt0.V); XYZ xyzPt1 = profilePlane.Origin + profilePlane.XVec.Multiply(uvPt1.U) + profilePlane.YVec.Multiply(uvPt1.V); XYZ xyzPt2 = profilePlane.Origin + profilePlane.XVec.Multiply(uvPt2.U) + profilePlane.YVec.Multiply(uvPt2.V); XYZ xyzPt3 = profilePlane.Origin + profilePlane.XVec.Multiply(uvPt3.U) + profilePlane.YVec.Multiply(uvPt3.V); Line l1 = Line.CreateBound(xyzPt0, xyzPt1); Line l2 = Line.CreateBound(xyzPt1, xyzPt2); Line l3 = Line.CreateBound(xyzPt2, xyzPt3); Line l4 = Line.CreateBound(xyzPt3, xyzPt0); CurveLoop loop = new CurveLoop(); loop.Append(l1); loop.Append(l2); loop.Append(l3); loop.Append(l4); List<CurveLoop> newloops = new List<CurveLoop>() { loop }; //Create the swept solid Solid sweepSolid= GeometryCreationUtilities.CreateSweptGeometry(pathCurveLoop, 0, 0, newloops); //Create a directShape to visualize the solid DirectShape ds = DirectShape.CreateElement(doc, new ElementId(BuiltInCategory.OST_GenericModel)); ds.AppendShape(new Solid[1] { sweepSolid }); trans.Commit(); return Result.Succeeded; } else { throw new InvalidOperationException("Current element is not a curve-dirven element"); } } }
Here is my code
Solved by aignatovich. Go to Solution.
Hi!
Replace this line with:
Solid sweepSolid = GeometryCreationUtilities.CreateSweptGeometry(pathCurveLoop, 0, lc.Curve.GetEndParameter(0), newloops);
Hi!
Dear Aignatovich,
It works! Thank you so much!
Dear Aignatovich,
