python: create start point/end point for each model line inside mass family
ellliaz
ellliaz
Hi, i created a family mass composed by model lines, i want to place a structural framing beam for each line i've in the family. i wrote a code to place a point at the beginning and end of each line, but i get an empty list as result. Do you have some suggestion?
import sys
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import *
clr.AddReference('RevitServices')
from RevitServices.Persistence import DocumentManager
doc = DocumentManager.Instance.CurrentDBDocument
points = []
mass_instances_collector = FilteredElementCollector(doc).OfClass(FamilyInstance).WhereElementIsNotElementType().OfCategory(BuiltInCategory.OST_Mass)
for mass_instance in mass_instances_collector:
    family = mass_instance.Symbol.Family
    if family.FamilyCategory.Id == BuiltInCategory.OST_Mass:
        mass_geometry = mass_instance.Symbol.get_Geometry(Options())
        for geo_obj in mass_geometry:
            if isinstance(geo_obj, GeometryInstance):
                geometry = geo_obj.GetInstanceGeometry()
                for g in geometry:
                    if isinstance(g, Line):
                        line = g
                        start_point = line.GetEndPoint(0)
                        end_point = line.GetEndPoint(1)
                        points.append((start_point.X, start_point.Y, start_point.Z))
                        points.append((end_point.X, end_point.Y, end_point.Z))
OUT = points
jeremy_tammik
The call to append a point to the list is wrapped in several if clauses. I would assume that one or more of those is failing, and therefore no points are added. Run your code in a debugger, step through it line by line, and you will see which assumptions are failing.
architect.bim
Hi!
In your case there is no need to get the Family and the Symbol Geometry for the mass element. Just extract the geometry directly from the instance and everything will work fine and you will get the desired points in the output.
    for g_element in mass_instance.Geometry[Options()]:
        if isinstance(g_element, GeometryInstance):
            for item in g_element.GetInstanceGeometry():
                if isinstance(item, Line):
                    start_point = item.GetEndPoint(0)
                    end_point = item.GetEndPoint(1)
Maxim Stepannikov | Architect, BIM Manager, Instructor
ellliaz
Thanks it solved the issue 😊 even though i changed the code a little
    mass_geometry = mass_instance.get_Geometry(Options())
            for g in geometry:
                    line = g
                    start_points.append(start_point)
                    end_points.append(end_point)
