Python AddParameter method question for Revit2023
f_cat
f_cat
My question is very similar to this post but could not solve my problem.
https://forums.autodesk.com/t5/revit-api-forum/how-to-use-forgetypeid-to-add-family-parameters-to-a-...
To add material parameter as family type parameter, here is my python code for Revit2020;
material_param = family_doc.FamilyManager.AddParameter("material_name",DB.BuiltInParameterGroup.PG_MATERIALS, DB.ParameterType.Material, False)
And I arranged it for 2023  but error occurs is this;
materialgroupTypeId = GroupTypeId.Materials
familyCategory= Category.GetBuiltInCategoryTypeId(BuiltInCategory.OST_Materials)
material_param = fam_doc.FamilyManager.AddParameter("material_name_string", materialgroupTypeId, familyCategory, False)
The error message came out when the code run is this;
Runtime error (ArgumentException): Not a spec
Parameter name: specTypeId
I created it based on the method
AddParameter(String, BuiltInParameterGroup, Category, Boolean)
however, should I be using
AddParameter(String, ForgeTypeId, ForgeTypeId, Boolean)
instead?
Would anyone be able to offer some advice?
Kato
RPTHOMAS108
For FamilyManager.AddParameter(String, ForgeTypeId, ForgeTypeId, Boolean)
Use SpecTypeId.Reference.Material for spec arg. (2nd ForgeTypeId).
And GroupTypeId.Materials (or some other group) for Group arg. (1st ForgeTypeId).
The overload you was trying to use is for controlling type of nested family.
f_cat
Thank you RPTHOMAS108,
Now I understand the construction of the method.
You saved my life!!!
Have a goood day!
