- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi! I am updating add-in codes for Revit 2021 to Revit 2023. I found that the function that I used for adding a family parameter with a given name in Revit 2021 was removed in Revit 2023.
In the codes for Revit 2021, I used "AddParameter(String, BuiltInParameterGroup, ParameterType, Boolean)". This function worked well, but was removed from Revit API 2023.
In the codes for Revit 2023, it seems that I have to use "AddParameter(String, ForgeTypeId, ForgeTypeId, Boolean)". What ForgeTypeIds should I use in this function for adding a family parameter?
Below is my codes for Revit API 2021. thanks!
Document familyDoc = doc.EditFamily(loadedFamily);
FamilyManager familyMgr = familyDoc.FamilyManager;
using (Transaction tx1 = new Transaction(familyDoc))
try
tx1.Start("AddCedWorksetToFamily");
FamilyParameter CedWorksetParameter = familyMgr.AddParameter("CedWorkset", BuiltInParameterGroup.PG_DATA, ParameterType.Text, true); //An instance parameter
FamilyParameter CedFamilyTypeParameter = familyMgr.AddParameter("CedFamilyType", BuiltInParameterGroup.PG_DATA, ParameterType.Text, false); //Not an instance parameter
FamilyTypeSet familyTypes = familyMgr.Types;
FamilyTypeSetIterator familyTypesItor = familyTypes.ForwardIterator();
familyTypesItor.Reset();
while (familyTypesItor.MoveNext())
FamilyType familyType = familyTypesItor.Current as FamilyType;
familyMgr.CurrentType = familyType;
familyMgr.Set(CedWorksetParameter, "Refrigeration");
familyMgr.Set(CedFamilyTypeParameter, "Refrigeration");
tx1.Commit();
catch (Exception e)
if (tx1 != null) tx1.RollBack();
TaskDialog.Show("Loading family", e.Message);
