pyRevit extension to toggle point cloud visibility
I'm trying to write a basic extension to toggle point cloud visibility in the active vew as shown below. But I receive this eror...
TypeError: bool is not callable
import clr
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
from Autodesk.Revit import DB
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
view = doc.ActiveView
t = DB.Transaction(doc)
t.Start('Set Pt Cloud Color Mode')
view.ArePointCloudsHidden(False, True)
t.Commit()
franciscopossetto
Hey,
It seems like you are trying to use the property ArePointCloudsHidden as a method. If you want to switch the visibility of the point cloud, you could use the method HideCategoryTemporary.
https://www.revitapidocs.com/2022/26684015-0635-cb13-d5a9-f6a6f9b0780a.htm
I have developed this tool before, it is on C# but you can see the code.
https://github.com/franpossetto/Nina/blob/master/Nina/Lib/PointCloud.cs
or download it.
https://github.com/franpossetto/Nina/releases
I hope it helps,
Kind regards.
Github:
jeremy_tammik
Thank you for the precise answer and the pointer to your nice and useful collection of tools!
P.S. Best regards to Nina as well.
franciscopossetto
Thank you @jeremy_tammik! I appreciate it.
I'll send Nina your regards!
Github:
Vey helpful, thankyou @franciscopossetto
juraj.kiaba
Observer
Observer
My solution for hiding and showing point clouds in active view (in pyRevit script file):
from Autodesk.Revit.DB import *
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PointClouds).WhereElementIsNotElementType()
elements = collector.ToElements()
pointclouds = collector.ToElementIds()
visible = False
for element in elements:
   if not element.IsHidden(doc.ActiveView):
      visible = True
      break
if visible:
   t = Transaction(doc,"Hide pointclouds")
   t.Start()
   doc.ActiveView.HideElements(pointclouds)
   t.Commit()
else:
   t = Transaction(doc,"Unhide pointclouds")
   t.Start()
   doc.ActiveView.UnhideElements(pointclouds)
   t.Commit()
