Purge Line Patterns
Purge Line Patterns
Dale.Bartlett
Purge Line Patterns
Dale.Bartlett
I can return all Line Patterns and IDs with:
FilteredElementCollector collector = newFilteredElementCollector(doc);
IList<Element> elems = collector.OfClass(typeof(LinePatternElement)).ToElements();
then process elems to select ones to purge, and add to:
IList <ElementId> idsToDelete = newList<ElementId>();
then delete by element iD:
tr.Start();
// all at once
// doc.Delete(idsToDelete);
// or
foreach (ElementId eid in idsToDelete)
 doc.Delete(eid);
tr.Commit();
However the elements (Line Patterns) are not being deleted from the document. Any thoughts? Thanks, Dale
______________
Yes, I'm Satoshi.
Did you try to make a collection of linepatterns like
doc.LinePatterns()
and delete each element in the collection like :
foreach (LinePatternElement line in doc.LinePatterns())
     doc.Delete(line.Id);
Dale.Bartlett
Thanks for the reply.
There is no definition for doc.LinePatterns...
Dale
______________
Yes, I'm Satoshi.
You are right, excuse me. I've made an extension for it. Looking at the code I'm doing the same a you. I make a collection of LinePatternElements. And looping through this collection I delete them.
FilteredElementCollector(doc).WherePasses(new ElementClassFilter(typeof(LinePatternElement))).OfType<LinePatternElement>().ToList();
Dale.Bartlett
Thanks Remy,
There have been some other published macros using similar code that presumably work. I haven't tested my code in multiple files, so possibly there is something in the file itself. Dale
______________
Yes, I'm Satoshi.
