Proxy element like AutoCAD user-defined entity
1. Whether revit has proxy element ( like a AutoCAD proxy entity) class type  ?
2. How to handle the move event in "Family" type?
3. Whether the Family has properties set family element be can not move ?
Man Happybest regards.
jeremytammik
Before doing anything else, you need to realise how different Revit and its API is from AutoCAD and most other CAD systems and APIs:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.41
  1. No.
  2. I guess you mean family instance, not type?
  3. Yes, you can pin and lock Revit elements.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Man Happy Thank you for a great answer! Heart
There is still a problem:
whether has a method to hand\catch a on-delete or on-move event from a family instance or image element?
I guess : no.
jeremytammik
