Properties panel sorting tool hides parameters
floetstephane
floetstephane
I just wanted to share a bug relating to the parameter sorting tool.
I found out that one ,of my shared parameters can not cohabitate in the same group with one other shared parameters. When both are in the same group, one of them disappears from the properties panel. My guess is they both have special characters in it (² and ³) and for some reason the properties panel in revit 2024 can't display both parameters in the same group.
Then i found out that the default sorting mode is the issue. By alphabethical sorting both parameters are visible and the one with ³ disappears in default sorting mode.
This worked fine in Revit 2023.
I hope it helps.
jeremy_tammik
There are always interesting new ways to create problems, aren't there? Thank you very much for raising this. I passed it on to the development team for you.
jeremy_tammik
Dear Florence,
Thank you for your report and sample images. Sorry to hear about this.
This is an end user UI product issue not related to the Revit API.
Still, I logged the issue REVIT-223639 [Properties panel sorting hides parameters with special characters] with our development team for this on your behalf as it requires further exploration and possibly a modification to our software. Please make a note of this number for future reference.
You are welcome to request an update on the status of this issue or to provide additional information on it at any time quoting this change request number.
This issue is important to me. What can I do to help?
This issue needs to be assessed by our engineering team and prioritised against all other outstanding change requests. Any information that you can provide to influence this assessment will help. Please provide the following where possible:
  • Impact on your application and/or your development.
  • The number of users affected.
  • The potential revenue impact to you.
  • The potential revenue impact to Autodesk.
  • Realistic timescale over which a fix would help you.
  • In the case of a request for a new feature or a feature enhancement, please also provide detailed Use cases for the workflows that this change would address.
This information is crucial. Our engineering team has limited resources and must focus their efforts on the highest impact items. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
Best regards,
Jeremy
jeremy_tammik
The development team analysed the issue REVIT-223639 [Properties panel sorting hides parameters with special characters] and determined a need for a code fix. This is logged in a new ticket REVIT-223746 [Properties panel sorting hides parameters with special characters]. Please make a note of this number for future reference. Thank you again for reporting this!
