Projectlocation set
Projectlocation set
Joris.vd.Meulen
Message 1 of 11
Projectlocation set
Joris.vd.Meulen
Guys,
Just to be sure: Revit API doesn't allow us to set a Projectlocation right?
So let's say you have 10 ProjectLocations and you want to set a specific one as the ActiveProjectLocation
love python coding
Replies (10)
Message 2 of 11
architect.bim
Hi!
I think it allows. In the latest API versions there is SetProjectPosition method
Maxim Stepannikov | Architect, BIM Manager, Instructor
Message 3 of 11
architect.bim
I'm sorry! The previous one changes the properties of the location itself. And this property (ActiveProjectLocation) is responsible for the current document location.
Message 4 of 11
Joris.vd.Meulen
Yeah,
So one can't set a specific one as ActiveLocation.
no API workflow would be: press the "make current" button
love python coding
Message 5 of 11
architect.bim
Sorry, I do not understand what the problem is. You simply need to set new value for the ActiveProjectLocation property. Here is Python sample. I create duplicate the existing location and set it as the current:
current_location = doc.ActiveProjectLocation
with DB.Transaction(doc, 'Set New Current Location') as t:
    t.Start()
    new_location = current_location.Duplicate('New Location')
    doc.ActiveProjectLocation = new_location
    t.Commit()
The results are in the screenshot below:
Message 6 of 11
architect.bim
To retrieve all the project locations get the ProjectLocations value and iterate through the ProjectLocationSet to get the location you need.
Message 7 of 11
Joris.vd.Meulen
As the screenshot above shows:
I have 3 defined sitelocations (each with the own survey point, rotation etc.etc.)
I want to make one of those current: as if I pressed the "make current" button
love python coding
Message 8 of 11
Joris.vd.Meulen
Ah that does work!
Thanks!
love python coding
Message 9 of 11
architect.bim
What stops you from doing so? Setting the ActiveProjectLocation property does the same as you if you push "Make Current" button in Revit UI.
Before:
Python Code:
all_locations = doc.ProjectLocations
for location in all_locations:
    if location.Name == 'New Location 2':
        break
    t.Start()
    doc.ActiveProjectLocation = location
    t.Commit()
After:
Message 10 of 11
architect.bim
Okay!
I am glad it finally helped. 😃
Message 11 of 11
Joris.vd.Meulen
You sure did bud!
love python coding
