Project Sweeper, ReVVed, and other apps now open source
kfpemail-2
Message 1 of 24
kfpemail-2
A while ago I decided to shut down pkh Lineworks and I discontinued work on my apps Project Sweeper, MLTE, ReVVed, Paraline and Knock Knock. I have now decided to make them open source so anyone can download the code and continue to update them for future versions of Revit.
The repositories can be found at this link: https://github.com/kfpopeye
Replies (23)
Message 21 of 24
rhanzlick
The solution is not straightforward, but potentially not easy. The solution is that the library files (files with extension *.dll) must be recreated referencing the RevitAPI resources from the respective version you would like it to work in. Assuming all source code is compatible, this just means rebuilding the source code in an IDE with references set to point at the right RevitAPI files.
However, Revit sometimes introduces breaking-changes between major versions. This means that you potentially need to edit the source code to support whatever changes are introduced (or removed) from each version independently.
Hope this at least helps you figure out a path forward. Good luck!
Message 22 of 24
ADesk-1CTXGJ
Observer
Observer
Hi, do yo mind sharing what exactly you did to make the app work in Revit 2024, I have tried the solution proposed by @purvigirwin  and it doesn't work for me.
Thanks alot
Message 23 of 24
NadeemAbdulHameed
I was trying with the same direction it's not work for Revit 2023 version
Message 24 of 24
adminFN7KX
Observer
Observer
Hi Carlos,
Mind telling how you were able to make it work?
Thank you
