Project Browser incorrect after posted error cancels rename of family type
harrymattison
harrymattison
Run the macro to register this updater that will post an error when an OST_Walls element is changed
Rename a wall type
The error is posted and the wall type is not renamed, but the project browser incorrectly shows the new name
 * Created by SharpDevelop.
 * User: harry_000
 * Date: 11/20/2019
 * Time: 12:51 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace FailureTest
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("1844902F-824D-4CCD-B7D1-FB8C8ECC04EA")]
	public partial class ThisApplication
		public static UpdaterId modificationId;
		public static FailureDefinitionId modificationFailureId;
		public static Autodesk.Revit.ApplicationServices.Application app;
		private void Module_Startup(object sender, EventArgs e)
			ThisApplication thisApp = sender as ThisApplication;
			app = thisApp.Application;
			modificationFailureId = new FailureDefinitionId(Guid.NewGuid());
			try
	            FailureDefinition.CreateFailureDefinition(modificationFailureId, FailureSeverity.Error, "ERROR!!!");
			catch (Exception ex)
				TaskDialog.Show("Exception3", ex.Message);
		public void registerUpdater()
			try
				modificationId = new UpdaterId(app.ActiveAddInId, new Guid("7f453eba-4b9a-40df-b637-eb62a9ebf008"));
				ModificationUpdater modificationUpdater = new ModificationUpdater();
				UpdaterRegistry.RegisterUpdater(modificationUpdater);
				UpdaterRegistry.AddTrigger(modificationUpdater.GetUpdaterId(), new ElementCategoryFilter(BuiltInCategory.OST_Walls), Element.GetChangeTypeAny());
				TaskDialog.Show("Exception2", ex.Message);
        public class ModificationUpdater : IUpdater
            public void Execute(UpdaterData data)
                Document doc = data.GetDocument();
                List<ElementId> modifiedIds = data.GetModifiedElementIds().ToList();
                foreach (ElementId id in modifiedIds)
                    FailureMessage failureMessage = new FailureMessage(modificationFailureId);
                    failureMessage.SetFailingElement(id);
                    doc.PostFailure(failureMessage);
            public string GetAdditionalInformation() { return "ModificationUpdater"; }
            public ChangePriority GetChangePriority() { return ChangePriority.FloorsRoofsStructuralWalls; }
            public UpdaterId GetUpdaterId() { return modificationId; }
            public string GetUpdaterName() { return "ModificationUpdater"; }
		private void Module_Shutdown(object sender, EventArgs e)
		#region Revit Macros generated code
		private void InternalStartup()
			this.Startup += new System.EventHandler(Module_Startup);
			this.Shutdown += new System.EventHandler(Module_Shutdown);
		#endregion
jeremytammik
Did you manually escalate your previous issue AssetPropertyDoubleArray4d.SetValueAsColor throws exception for some materials, or did it happen automatically?
If the former, can you do it for this one as well?
Thank you!
Jeremy Tammik
Developer Technical Services
The Building Coder
harrymattison
Hi Jeremy
When I click "need an answer" there is this error
jeremytammik
Your previous thread mentioned above was escalated to an ADN, FPD, SFDC case, somehow...
Jeremy Tammik
The Building Coder
