Problems with External Event in modeless form
I have a code for a modeless form and I keep getting an error on starting a transaction. If I use ShowDialog it works fine. I can't seem to figure how to create a working modeless dialog fo
[Transaction(TransactionMode.Manual)]
    class FormShow : IExternalCommand
        public Result Execute(ExternalCommandData c, ref string m, ElementSet e)
            ExternalEvent x = ExternalEvent.Create(new ExHandler());
            UIApplication u = c.Application;
            new Form1(x, u).Show();
            return Result.Succeeded;
        class ExHandler : IExternalEventHandler
            public void Execute(UIApplication ap) { }
            public string GetName() { "form1" }
    class Form1 : Form
        ExternalEvent x;
        UIApplication u;
        Document d;
        public Form1(ExternalEvent e, UIApplication a)
            InitializeComponent();
            x = e;
            u = a;
            d = u.ActiveUIDocument.Document;
        private void Button1_Click(object sender, EventArgs e)
            x.Raise();
            using (Transaction t = new Transaction(d, "command"))
                t.Start();
                //do something
                t.Commit();
            this.Close();
r Revit.
jeremytammik
Please first take a look at the Revit SDK sample ModelessDialog/ModelessForm_ExternalEvent.
That is the official documentation showing how to set things up.
Several other samples and discussions are shared by The Building Coder in the topic group on external events for modeless access and driving Revit from outside:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
SamBerk
Hi @Anonymous
The problem with your code is that you are starting the transaction inside the button click handler.
You have to do it in the IExternalEventHandler.Execute method, and it will get executed when you call x.Raise();
like this:
using (Transaction t = new Transaction(ap.ActiveUIDocument.Document, "command"))
t.Start();
//do something
t.Commit();
} public string GetName() { "form1" } } } class Form1 : Form { ExternalEvent x; UIApplication u; Document d; public Form1(ExternalEvent e, UIApplication a) { InitializeComponent(); x = e; u = a; d = u.ActiveUIDocument.Document; } private void Button1_Click(object sender, EventArgs e) { x.Raise(); this.Close(); } }
