Problem with LoadFamily method
sean_dodsworth
sean_dodsworth
Hi All,
I'm having trouble using the Document.LoadFamily method to load a family when an older version of the family exists in the model.
My code looks like this:
public class FamilyLoadOptions : IFamilyLoadOptions
        public bool OnFamilyFound(bool familyInUse, out bool overwriteParameterValues)
            overwriteParameterValues = true;
            return true;
        public bool OnSharedFamilyFound(Family sharedFamily, bool familyInUse, out FamilySource source, out bool overwriteParameterValues)
            source = FamilySource.Family;
            return true;
Family loadedFamily = null;
var success = doc.LoadFamily(localPath, new FamilyLoadOptions(), out loadedFamily);
When the family already exists in the model success is always false and loadedFamily is always null.
Also when I try to debug the FamilyLoadOptions neither of its methods are every accessed.
Thanks in advance,
Sean
aignatovich
Hi, Sean!
Did you try to change anything in your family before loading it into the project? If nothing changed, Revit will not load it to the document
sean_dodsworth
Yeah you're right, the family I was loading in must have been unchanged even though I had copied it to a different location.
Out of interest how does Revit know if one family is the same as another? Does it actually compare them element by element?
aignatovich
Don't know exactly, may be it just compares the hash of the families contents
jeremytammik
Dear Sean,
Thank you for your query, and to Alexander for his succinct, precise, complete answer.
Here are some previous discussions of thsis topic:
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
sean_dodsworth
Hi Jeremy,
I did try searching but didn't find the links you just posted.
This one is exactly what I was looking for: http://thebuildingcoder.typepad.com/blog/2011/10/reloading-a-family-again.html
It would be great if the SDK documentation for the LoadFamily method included that bit of information.
- Sean
