Problem with hook rotation when using Rebar.CreateFreeForm
I've been creating rebars with Rebar.CreateFreeForm and everything works great when I create a bar with 2 points, however when I try to create rebars with more than 2 points I can't control the hook bar rotation, some hooks are set correctly but others are not, even when they have the same hook type and rotation, as shown below:
I've being trying to compare all parameters and they are pretty much the same for both bars, and I'm not sure what the problem is.
Thanks in advance.
I solved it already.
Instead of using the constructor
public static Rebar CreateFreeForm(
	Document doc,
	RebarBarType barType,
	Element host,
	IList<IList<Curve>> curves,
	out RebarFreeFormValidationResult error
And getting and setting hook parameters like type and rotation (Where hook orientation seemed to change based on rebar coordinates.)
I used this contructor instead, which usesRebarHookOrientation startHookOrientRebarHookOrientation endHookOrient, and solves the problem.
public static Rebar CreateFromCurves(
	Document doc,
	RebarStyle style,
	RebarHookType startHook,
	RebarHookType endHook,
	Element host,
	XYZ norm,
	IList<Curve> curves,
	RebarHookOrientation startHookOrient,
	bool useExistingShapeIfPossible,
	bool createNewShape
Hope it helps somebody with the same problem.
