Problem with Element.get_Parameter(Builtinparameter) -> returns null
Hello everyone,
I am trying to get an element's parameter by using the parameter id. However, it returns null!?
By debugging, I am sure that, in my code "bparam" gets created with the provided id. I am also sure that I am looking to the right element which is a Wall and the parameter I'm trying to get is "ANALYTICAL_ABSORPTANCE". So the element definitely has this parameter.
Why would the get_parameter method returns null?? What could be the cause?
int pId = -1005435;
BuiltInParameter bparam = (BuiltInParameter) pId;
Parameter p = e.get_Parameter(bparam);
p.SetValueString(value);
RPTHOMAS108
That's a parameter from an element type such as WallType, so is 'e' an element type (found from the instance via Element.GetTypeId)?
The usual reason for that returning null is that the parameter doesn't exist on the element.
SamBerk
Hi @Anonymous
Since ANALYTICAL_ABSORPTANCE is a type parameter you have to call get_Parameter from the type element not from the instance element.
2 Options:
Option 1 - Cast to Wall type
Wall wall = e as Wall;
Parameter p = wall.WallType.get_Parameter(bparam);
Option 2 - Get TypeId
Element wallType = document.GetElement(e.GetTypeId());
Parameter p = wallType.get_Parameter(bparam);
Thank you very much SamBerk and RPTHOMAS108!!!
