Problem installing Revit 2016
hafizn.honeywell
hafizn.honeywell
Attached is the log
The process always stop at Visual C++ Redistributable.....
I hope someone can help me on this.
caroline.gitonga
Hi @hafizn.honeywell,
This particular forum is dedicated for Revit API questions only or rather, programmatical problems related to Revit API. It is best you channel your issue to Revit installation forum you will get a better solution.
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Carol Gitonga, Developer Advocacy and Support, ADN Open
