Closed sweep alternative/workaround?
Hi All,
I've searched and tested some other instances on the forum but nothing changed the result. I want to create face-based family of a sink that can be adjusted to specific sizes. I'm trying to model a parametric sink, but the closed (and open, I tried) sweep fails to generate. One alternative is to just model 15 different sink sizes and allow users to pick them, but I want to cut out such input and file sizing. Ideally, the result would be 1 sink of 3 or so elements at most if doable, and parametric in depth, width and height.
The top 2 views are my base for 1 sink. The current sweep is cut 1mm short from the bottom to avoid a square interior perimeter (which causes the sweep to fail to generate), but applying parametric dimensions to this is causing constraint issues.
Bottom 2 views are the easy way out, but I'd like to avoid the many user options and file size this creates.
Any ideas or alternative suggestions?
