Print View Template Settings
62BJW
62BJW
Does anyone know if it's possible to print a view template's settings? Either with the API or a pre-made application. I have 75 or so view templates that I need to print out and I'm hoping not to do a ton of screen captures which is very time consuming.
so-chong
Hi Bernie,
Are you aware of there is a "Boost Your BIM" weblog by Harry Mattison?
From there if you search for viewtemplate you will get this topic, i assume
https://boostyourbim.wordpress.com/2015/10/31/rtceur-wish-5-view-template-partially-exported/
I hope this is useful for you.
Thanks to Harry for publishing and sharing the code on his weblog.
Cheers,
So-Chong
