Print Manager, Papresize, Paper orientation
Message 1 of 9
Hi
I have tried (a lot) to get the right orientation and papresize in a pdf plot
I got the right printer, the right filename
but not the right papersize and orientation, I am usingBoundingBoxUV to get the Sheetsize and from there the orientation of the sheet
that works fine šŸ™‚
I have been trying with 3 different pdf printers, without luck šŸ˜ž
My the code looke like this, in this case I am trying to print all shests starting with an "A" to be printet in A3.
PrintManager PrintM = OpenDoc.PrintManager;
PrintM.PrintSetup.CurrentPrintSetting = PrintM.PrintSetup.InSession;
PrintM.SelectNewPrintDriver("PDF995"); //("CutePDF Writer")("PDF995")("PDFCreator")
PrintM.PrintToFile = true;
foreach (ViewSheet vs in new FilteredElementCollector(OpenDoc).OfClass(typeof(ViewSheet)).Cast<ViewSheet>())
if (vs.SheetNumber[0].ToString() != "A")
PDF_Name = vs.SheetNumber.Substring(0, vs.SheetNumber.Length - 3);
PrintM.PrintToFileName = DistFolder + @"\" + Department_number.AsString() + "-" + PDF_Name;
PaperSizeSet PaperSizeSet = PrintM.PaperSizes;
PrintM.PrintSetup.CurrentPrintSetting.PrintParameters.PageOrientation = PageOrientationType.Portrait;
foreach (PaperSize PS in PaperSizeSet) // Finding the right papersize in the printer
if (PS.Name.ToString() == "A3")
PrintM.PrintSetup.CurrentPrintSetting.PrintParameters.PaperSize = PS;
break;
PrintM.Apply();
PrintM.SubmitPrint(vs);
} // end of foreach (ViewSheet vs........
What do I do wrong ??
Regards
Anders
Replies (8)
Message 2 of 9
Aaron.Lu
Hi Enthusiast, I did not find any problem of your code, I don't have PDF995 driver, but I tried "Foxit Reader PDF Printer", it works well.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
Hi
I didn't have "Foxit Reader PDF Printer" but I have nov šŸ™‚
But it still don't work on my computer
I doesn't make it portrait and I still can't get the right papersize
Do you have some special settings on the printer  ??
Anders
Message 4 of 9
Aaron.Lu
looks like you need to get a setting object, modify it, and set it back, would you like to try this?
var setting = PrintM.PrintSetup.CurrentPrintSetting;
// change properties of setting objecct
PrintM.PrintSetup.CurrentPrintSetting = setting;
PrintM.Apply();
Aaron Lu
Message 5 of 9
Hi
It still doesn't work.
When I restart Revit it will print all the sheets with the Papersize, I have set for the first sheet
Whitch meens that Revit have control of the printer, but in the Revit session, and not sheet by sheet
And the orientation is still the same šŸ˜ž
and the PrintM.PrintToFileName .... give the files the right name, but not in the right folder, but in the printer default save folder
My code look like this, have I used "setting" in the right way or ???
InSessionPrintSetting inSessionPrintSetting = PrintM.PrintSetup.CurrentPrintSetting as InSessionPrintSetting;
if (vs.SheetNumber[0].ToString() != "A4")
PrintM.PrintToFileName = DistFolder + @"\" + Association_number.AsString() + "-" + Department_number.AsString() + "-" + PDF_Name + " - Plan.";
PaperSize Printerpapersizes = PrintM.PrintSetup.CurrentPrintSetting.PrintParameters.PaperSize;
setting.PrintParameters.PageOrientation = PageOrientationType.Portrait;
if (PS.Name.ToString() == pps.ToString())
setting.PrintParameters.PaperSize = PS;
break;
PrintM.Apply();
Anders
Message 6 of 9
Aaron.Lu
Thanks for checking.
Now I've got another extra step, that is: save the setting, then the in-session setting will be actually changed. Hope it can work.
    using (Transaction transaction = new Transaction(doc))
        transaction.Start("save setting");
        PrintM.PrintSetup.SaveAs("newsetting");
        transaction.Commit();
    PrintM.Apply();
Aaron Lu
Message 7 of 9
Hi
We are gettting close šŸ™‚
Revit couldn't not delete or overwrite the saves setting, so I rolled the transaction back after printing, that worked
Transaction transaction = new Transaction(OpenDoc);
PrintM.PrintSetup.SaveAs("Tempsetting");
PrintM.Apply();
transaction.RollBack();
But I still can't get the printer to save the pdf file in the right place, Do you have any ideas to fix that ?
Regards
Anders
Message 8 of 9
Revitalizer
"But I still can't get the printer to save the pdf file in the right place":
what about just moving the file to the correct place, after printing  ...?
Not a solution but a workaround.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 9 of 9
Yes šŸ™‚
But I have > 100 useres, I they all have to set the settings right, to be sure that the printer saved in the same place so I know where to move the file from !!
