Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
PostCommand() takes exactly 2 arguments (1 given)
4 REPLIES 4
davidvadkerti
1699 Views, 4 Replies
I was trying to run Purge Unused command by following code:
Command_ID=RevitCommandId.LookupPostableCommandId(PostableCommand.PurgeUnused)
UIApplication.PostCommand(Command_ID)
It gets me this error:
As I understand explanation at revitapidocs it should take just one argument. Can you tell me what I got wrong please?
Thanks a lot.
4 REPLIES 4
UIApplication is a class. You need an instance. I assume the instance is regarded as the first argument. Look at other PostCommand samples:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.3
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks a lot Jeremy!
I am not familiar with C# in any sense, but your hint helped me a lot. I am using Python in Revit Python Shell and Pyrevit. My solution was like this:
#calling command Purge Unused
from Autodesk.Revit.UI import UIApplication, RevitCommandId, PostableCommand
doc = __revit__.ActiveUIDocument.Document
#alternative way of getting command ID
#Command_ID=RevitCommandId.LookupCommandId("ID_PURGE_UNUSED") uiapp = UIApplication(doc.Application) UIApplication.PostCommand(uiapp,Command_ID)
I supose there isn't any other way to run command and submit it (like clicking on OK button). At least I haven't found any direct way in Revit API.
You are still using a method on the class:
The normal thing to do is to call a method on the class instance instead.
That is shorter and more readable:
  uiapp.PostCommand(Command_ID)
And, as you see, only one argument is provided.
The instance implicitly becomes an argument as well, the first argument, often called `this`.
Read a bit on Python object oriented programming basics before proceeding any further.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Thanks for advice.
