PostCommand MirrorProject Command
jacsmithstrongtie
jacsmithstrongtie
Does anyone have any experience working with the PostableCommand.MirrorProject Post Command?  Also does the Post Command work from clicking a button in the ribbon or does the command generate automatically?  Sorry I am a new developer, and I am trying see if I can automate the Mirror Project feature in Revit 2024.  Our App No longer supports the ElementTransformUtils.MirrorElements method since upgrading to Revit 2024 with out genrating erros in the project.
moturi.magati.george
Hi @jacsmithstrongtie,
A similar question was raised on this forum https://forums.autodesk.com/t5/revit-api-forum/elementtransformutils-mirrorelements-error-when-upgra... and was logged by @jeremy_tammik as an issue with ticket no REVIT-207038 [MirrorElements fails although CanMirrorElements returns true] with the development team.
You will receive an update once they give a solution or workaround on the same.
  Moturi George,     Developer Advocacy and Support,  ADN Open
jacsmithstrongtie
Hello @moturi.magati.george,
This post was from my teammate.  We are both trying to find a solution for this problem.  I just learned that a user can flip the entire plan in the manage tab. Under the Position Location.  Just looking if I can replicate this behavior through the API instead to save our users a few button clicks.
