PostableCommand Issues
A number of PostableCommands do not seem to be working properly.  I'm using Revit 2014 UR3.  An example macro:
		public void PostMyOwnCommand()
            Application app = this.Application;
            UIApplication uiApp = new UIApplication(app);
            uiApp.PostCommand(RevitCommandId.LookupPostableCommandId(PostableCommand.PlanRegion));
When running this in a plan, the ribbon flashes and then nothing happens.  Also PostableCommand.TypeProperties does nothing as well even when an element such as a Wall is selected.
The following don't work properly either, although they work when placing multiple instances but if you try to place one instance it won't stay:
PostableCommand.Area      PostableCommand.BuildingElevation     PostableCommand.ColorFillLegend
I have not tested in Revit 2015 yet.  Thanks.
Also, if you try PostableCommand.Camera it works great until you hit Esc after the new view is created and Revit completely crashes.
