How to select a model line and convert to a curve using C# and Revit 2014
Im trying to have the user select two lines and I want the Revit API to return the XYZ location of the intersection of those two lines that were selected. So far I have been able to get to the part where the user can select the model lines.
Reference referenceLine1 = choices.PickObject(ObjectType.Element,selFilter, "Please select a model line.");
Reference referenceLine2 = choices.PickObject(ObjectType.Element, selFilter, "Please select your other model line.");
Element elementLine1 = doc.GetElement(referenceLine1.ElementId);
Element elementLine2 = doc.GetElement(referenceLine2.ElementId);
How to I convert the referenceLine1 object to a Curve class so that I can use the Curve.Intersect method from the revit API to test if two lines intersect?
I am trying to do this:
IntersectionResultArray resultArray;
SetComparisonResult compareResult = Curve1.Intersect(Curve2);
I am pretty sure it involves some type of casting or a "getCurve" method of some sort, but I cannot figure out exactly how.
I saw on Jeremy Tammik post that he does this with a line object. If I have a model line, how do I do this with a Model Line that the user has selected? Here is the post where he does this.
http://thebuildingcoder.typepad.com/blog/2010/06/intersection-between-elements.html
private XYZ GetIntersection(
    Line line1,
    Line line2 )
    IntersectionResultArray results;
    SetComparisonResult result
      = line1.Intersect( line2, out results );
    if( result != SetComparisonResult.Overlap )
      throw new InvalidOperationException(
        "Input lines did not intersect." );
    if( results == null || results.Size != 1 )
        "Could not extract line intersection point." );
    IntersectionResult iResult
      = results.get_Item( 0 );
    return iResult.XYZPoint;
hvarjus
I'm not sure if this is easiest way to do that but I think it should work in this way:
LocationCurve locationCurve1 = elementLine1.Location as LocationCurve;
LocationCurve locationCurve2 = elementLine2.Location as LocationCurve;
locationCurve1.Curve.Intersect(locationCurve2.Curve);
How about this:
/// <summary>
/// find the number of intersection points for two segments
/// </summary>
/// <param name="line0">first line</param>
/// <param name="line1">second line</param>
/// <returns>number of intersection points; 0, 1, or 2</returns>
public static int FindIntersection(Line2D line0, Line2D line1)
PointF[] intersectPnt = new PointF[2];
return FindIntersection(line0, line1, ref intersectPnt);
/// <summary>
/// find the intersection points of two segments
/// </summary>
/// <param name="intersectPnt">0, 1 or 2 intersection points</param>
public static int FindIntersection(Line2D line0, Line2D line1, ref PointF[] intersectPnt)
// segments p0 + s * d0 for s in [0, 0], p1 + t * d1 for t in [0, 1]
PointF p0 = line0.StartPnt;
PointF d0 = MathUtil.Multiply(line0.Length, line0.Normal);
PointF p1 = line1.StartPnt;
PointF d1 = MathUtil.Multiply(line1.Length, line1.Normal);
PointF E = MathUtil.Subtract(p1, p0);
float kross = d0.X * d1.Y - d0.Y * d1.X;
float sqrKross = kross * kross;
float sqrLen0 = d0.X * d0.X + d0.Y * d0.Y;
float sqrLen1 = d1.X * d1.X + d1.Y * d1.Y;
// lines of the segments are not parallel
if (sqrKross > MathUtil.Float_Epsilon * sqrLen0 * sqrLen1)
float s = (E.X * d1.Y - E.Y * d1.X) / kross;
if (s < 0 || s > 1)
// intersection of lines is not point on segment p0 + s * d0
return 0;
float t = (E.X * d0.Y - E.Y * d0.X) / kross;
if (t < 0 || t > 1)
// intersection of lines is not a point on segment p1 + t * d1
return 0;
// intersection of lines is a point on each segment
intersectPnt[0] = MathUtil.Add(p0, MathUtil.Multiply(s, d0));
return 1;
// lines of the segments are paralled
float sqrLenE = E.X * E.X + E.Y * E.Y;
float kross2 = E.X * d0.Y - E.Y * d0.X;
float sqrKross2 = kross2 * kross2;
if (sqrKross2 > MathUtil.Float_Epsilon * sqrLen0 * sqrLenE)
// lines of the segments are different
return 0;
// lines of the segments are the same. need to test for overlap of segments
float s0 = MathUtil.Dot(d0, E) / sqrLen0;
float s1 = s0 + MathUtil.Dot(d0, d1) / sqrLen0;
float smin = MathUtil.GetMin(s0, s1);
float smax = MathUtil.GetMax(s0, s1);
float[] w = new float[2];
int imax = MathUtil.FindIntersection(0.0f, 1.0f, smin, smax, ref w);
for (int i = 0; i < imax; i++)
intersectPnt[i] = MathUtil.Add(p0, MathUtil.Multiply(w[i], d0));
return imax;
