postable command usage
Ning_Zhou
Message 1 of 45
Ning_Zhou
seems postable command usage is quite limited, for instance
1) can only send warning message instead of disable command?
2) OOTB duplicate view will name that duplicated view w/ suffix Copy 1, is it possible to name it differently?
Replies (44)
Message 2 of 45
jeremytammik
Regarding your question 2, you could react to the new view creation and rename it afterwards in an additional step, either using DMU or the document changed event.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 45
Ning_Zhou
right, i'll give it a try, thanks Jeremy!
by the way, don't know if i can use ElementTypeDuplicated Event? i assume view duplicating is instance based operation, isn't it?
Message 4 of 45
Sean_Page
If you add Command Binding to the applicable Postable Commands you can indeed disable them by just making them do nothing, or giving the user a warning.
DMU is my preferred method to catch new views and rename them.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Message 5 of 45
Ning_Zhou
i did a quick test using document changed event, seems i cannot start transaction in order to change view name, did i miss something?
public void AppDocumentChanged(object sender, Autodesk.Revit.DB.Events.DocumentChangedEventArgs args)
ICollection<ElementId> views = new FilteredElementCollector(doc).OfClass(typeof(View)).ToElementIds();
ICollection<ElementId> ids = args.GetAddedElementIds();
foreach (ElementId id in ids)
if (views.Contains(id))
Element e = doc.GetElement(id);
string name = Regex.Replace(e.Name, @" Copy 1", "_zn"); // name changed successfully
using (Transaction tx = new Transaction(doc))
tx.Start("renameTransaction");
try
e.Name = name;
catch (Exception ex)
MessageBox.Show(ex.Message);
tx.Commit();
Message 6 of 45
Sean_Page
I do not believe you can produce a Transaction during this event. It is a read only event according to the docs.
https://www.revitapidocs.com/2015/988dd6cf-fcaa-85d2-622d-c50f13917a13.htm
That is why DMU is so nice, it happens in a transaction already so no need to start another one.
Message 7 of 45
Sean_Page
Also, are you missing { } on your foreach?
Message 8 of 45
Ning_Zhou
thanks spage, can you elaborate on Command Binding thing to disable / give warning? yes, i'll try DMU later as suggested by Jeremy too
Message 9 of 45
Ning_Zhou
good to know that document changed event is read only, perhaps factory should provide us w/ document changing event too?
i skipped {} as only one if statement here, well, not good practice, thanks again
Message 10 of 45
Sean_Page
See here.
https://boostyourbim.wordpress.com/2013/01/14/how-to-override-commands-in-the-revit-ui-if-you-really...
Message 11 of 45
Ning_Zhou
thanks spage, works great! what if i want to give warning only and continue that command in OOTB way?
Message 12 of 45
Sean_Page
You would need to Remove the command binding after the warning and the use a PostCommand to call the initial CommandId.
You can also use Idle handlers to create the binding again if you want it to happen every time and not just the first time.
Message 13 of 45
Ning_Zhou
right, i need to use idle stuff to make sure it works every time, thanks.
Message 14 of 45
Ning_Zhou
hi spage, for idle event, which scope should i put into, app or cmd? if i put @ app scope i.e. startup then it's one time only, if i put @ cmd scope then how can i use OOTB import command instead of addin command?
Message 15 of 45
Sean_Page
So I have it in the Application level.
1. On Startup Biding and capturing the application for later use.
        public Result OnStartup(UIControlledApplication application)
            ControlID.application = application;
            AddCommandBindings(application, "ID_INPLACE_COMPONENT");
            return Result.Succeeded;
2. Add the Command Binding and the Method to call when it captures the command.
        private Result AddCommandBindings(UIControlledApplication application, string name)
            RevitCommandId rCommandId = RevitCommandId.LookupCommandId(name);
            if (rCommandId.CanHaveBinding)
                try
                    if (name == "ID_INPLACE_COMPONENT")
                        application.CreateAddInCommandBinding(rCommandId).Executed += new EventHandler<ExecutedEventArgs>(this.DisableCommand);
                catch
                    MessageBox.Show("Command " + name + " is already bound.");
3. This is the Method the CommandBinding calls when fired
private void DisableCommand(object sender, ExecutedEventArgs args)
            ControlID.postCommand = args.CommandId.Name;
            using (Forms.RevitPostCommandForm rpc = new Forms.RevitPostCommandForm())
                if (rpc.ShowDialog() == DialogResult.OK)
                    UIDocument uiDoc = new UIDocument(args.ActiveDocument);
                    uiDoc.Application.RemoveAddInCommandBinding(args.CommandId);
                    uiDoc.Application.PostCommand(args.CommandId);
                    ControlID.application.Idling += new EventHandler<IdlingEventArgs>(InPlaceComponent_Idling);
4. Use the associated idling event to Add the command binding back after it has fired the second time.
        private void InPlaceComponent_Idling(object sender, IdlingEventArgs args)
            AddCommandBindings(ControlID.application, "ID_INPLACE_COMPONENT");
            ControlID.application.Idling -= InPlaceComponent_Idling;
 public static class ControlID
            public static UIControlledApplication application { get; set; }
Message 16 of 45
Ning_Zhou
thanks spage, works great! except that i have to click OK twice, means that DisableCommand being executed twice, i assume it cannot be avoided because that same command being posted again, perhaps if i missed something?
Message 17 of 45
Sean_Page
I am not somewhere I can test, but I think the Postcommand is queued until after all the other code runs, which means the Idling event is actually firing first. Maybe a Thread.Sleep(2000) in the Idling will give the PostCommand a chance to fire. Not positive on that.
Message 18 of 45
Ning_Zhou
i did quick test, no, doesn't work, just delayed.
Message 19 of 45
Sean_Page
Looking back at my code which is working for me, the only thing I see is that I have the idler handler BEFORE the post command.
Message 20 of 45
Ning_Zhou
thanks spage, still doesn't work, the only difference is that i used window message box
DialogResult result = MessageBox.Show("click OK to continue importing but your action will be logged", "BIM & DD", MessageBoxButtons.OKCancel);
if (result == DialogResult.OK)
uiApp.RemoveAddInCommandBinding(arg.CommandId);
uiApp.Idling += new EventHandler<IdlingEventArgs>(OnIdling);
uiApp.PostCommand(arg.CommandId);
