Polycurve by joint curves
Hi all,
I'm new in Revit API.
I want to create a polycurve by joint curves like a node in Dynamo.
But i dont find a class Polycurve. I dont know how to do
Thanks for your help
recepagah12
If you are new in Revit API, you should start looking to getting started materials. First, you need to understand how Revit API works, then start coding. When you are done with learning basics, you can learn how to create polycurve by joint curves via debugging dynamo node itself. Here is a link for getting started to Revit API.
Getting Started to Revit API
I hope this helps,
Recep.
Thanks for your advice. I have started with the documentations on Revit API for two months, but i dont find a method which permit joint a line and a arc like in dynamo. I found method for Polyline not polycure. Do you know a method creating a polycurve?
