Playing Journal Files
AGGilliam
AGGilliam
I just recently learned about this functionality and decided to try and test it out to see if I could take advantage of it. I opened Revit, imported some keyboard shortcuts, closed Revit, then copied the journal file to my desktop. To test it, I reset my keyboard shortcuts then opened the journal file with Revit. It seemed to work successfully; Revit opened and closed without any errors. But, when I opened Revit back up, the keyboard shortcuts weren't updated like I expected them to be.
Is this to be expected? I'm not sure if I'm just missing a step or if it just doesn't function that way.
jeremy_tammik
Interesting observation.
Basically, officially, the use of journal files for programming and customisation purposes is not supported.
On the other hand, journal files provide a lot of useful functionality and are used in many ways.
I cannot comment on the keyboard shortcut behaviour you describe.
Here are a couple of possibly outdated explorations described by The Building Coder:
