Placing lights at different heights
dallaspr1
dallaspr1
Can someone explain to me why I can place a ceiling fan in Bedroom with a 10' ceiling ht but when I try and place it in the family room with a 20' ceiling, it can't be placed on the ceiling?  Same problem with can lights.
jeremytammik
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically yourself, or just using the standard Revit user interface?
If you are not doing anything programmatically, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
You cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Jeremy Tammik
Developer Technical Services
The Building Coder
dallaspr1
Thanks for your response.  I figured that out after posting it.  I posted on a different forum and got an answer.
Thanks again.
