Cannot find 2021 US Imperial
Hello, I am looking to load door and window families. I cannot find the normal US Imperial folder that I have seen in the past and when selecting the English Imperial there is no load options. Please view attached images.
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, if you are not programming anything yourself using the Revit API, this is not the right place for this question.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Jeremy Tammik
Developer Technical Services
The Building Coder
