Place family instance into RVT file
I have a problem with placing family instance into rvt project file using Design Automation,
I tested that solution localy with design automation debugger and it worked fine. I recieving nullReference error when I try to get Family symbol by
var list = new FilteredElementCollector(Document)
               .OfClass(typeof(FamilySymbol));
You need to first load your family into Revit.
Then get the symbol and create an instance of family as shown below.
uiApp.ActiveUIDocument.Document.LoadFamily(GlobalVariables.FamilyPath + "Grid_Mass.rfa", out fm);
FamilySymbol MassISymbol = GetSymbol("Grid_Mass", "Grid_Mass");
FamilyInstance MassInstance = Doc.Create.NewFamilyInstance(new XYZ(0,0,0), MassISymbol, level, Autodesk.Revit.DB.Structure.StructuralType.UnknownFraming);
public FamilySymbol GetSymbol(string FamilyName, string TypeName)
try
FilteredElementCollector collector = new FilteredElementCollector(Doc).OfClass(typeof(FamilySymbol));
List<FamilySymbol> symbols = collector.ToElements().Cast<FamilySymbol>().ToList().Where(item => item != null).ToList();
var query = from item in symbols where item.Name == FamilyName  && item.FamilyName == FamilyName select item;
FamilySymbol symbol = query.FirstOrDefault() as FamilySymbol;
if (symbol != null)
using (Transaction actrans = new Transaction(Doc, "Activate Symbol"))
actrans.Start();
if (symbol.IsActive == false)
symbol.Activate();
actrans.Commit();
return symbol;
catch { }
return null;
