Is a model Workshared without opening the file
david_rock
david_rock
Can I tell if a model is Workshared without opening the file?
Also, can I tell the models version without opening the file?
Also, can I tell the local file folder without opening the file>
Kind Regards
David
jeremytammik
All of the information you can retrieve from an RVT file without opening it is provided by the BasicFileInfo class:
https://www.revitapidocs.com/2020/475edc09-cee7-6ff1-a0fa-4e427a56262a.htm
Look there to see whether the data you need is accessible or not.
Jeremy Tammik
Developer Technical Services
The Building Coder
david_rock
Perfect thank you,
I still need to dig through the Revit.ini file for the local folder. But I don't think there is currently any API for that.
Kind Regards
David
