Place a family instance by Python
Dear All,
I am trying to place a family instance by the code from: http://wiki.theprovingground.org/revit-api-py-family. I opened an Mass.rtf file, pasted the code in Interactive Python Shell, but it doesn’t work.
import clr
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
from Autodesk.Revit.DB import *
 app = __revit__.Application
doc = __revit__.ActiveUIDocument.Document
t = Transaction(doc, 'Create family instance.')
t.Start()
#Family symbol name to place.
symbName = 'BoxFamily'
#create a filtered element collector set to Category OST_Mass and Class FamilySymbol
collector = FilteredElementCollector(doc)
collector.OfCategory(BuiltInCategory.OST_Mass)
collector.OfClass(FamilySymbol)
famtypeitr = collector.GetElementIdIterator()
famtypeitr.Reset()
#Search Family Symbols in document.
for item in famtypeitr:
    famtypeID = item
    famsymb = doc.get_Element(famtypeID)
    #If the FamilySymbol is the name we are looking for, create a new instance.
    if famsymb.Family.Name == symbName:
        #location to place family
        loc = XYZ(0,0,0)
        #NewFamilyInstance()
        familyInst = doc.FamilyCreate.NewFamilyInstance(loc, famsymb, Structure.StructuralType.NonStructural)
t.Commit()
__window__.Close()
As a poor rookie, I was confused by the 'BoxFamily' which I guess it is a family instance, introduced and defined by the programmer. So I want to print all family names, so I tried:
    famtypeID = item
    print (famsymb.Family.Name)
Still nothing.
So can anyone tell me how to print all the family name? and how to define a symbol such as the 'BoxFamily' so I can place my own instances?
Thank you for your help to a rookie who has now been crazy.
Robin
jeremytammik
Welcome to the Revit API!
Do you understand the concepts of families, types and instances?
Do you have any experience with Revit?
I think you should maybe start with something simpler and gather some experience first.
Here are some hints on getting started with the Revit API:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Good luck and have fun!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Dear Jeremy, thanks for your kindly reply. I have swum in your Building Coder and BBS in the last two months, luckily I got survived.
I need to create a new family and insert into the project first, then I can use the code to place the family instance.  Thanks.
Hi Chunhuang, I also need to place a family with python and I came across the same code from the the website. However, I have the same issue as you had before. May I know how did you solve it? I inserted the family first and then ran the code, bus still got nothing. I am assuming the I input the wrong family symbol? Can you give me an example of what the family symbol is? I thought it is just the family type?  Thanks!
stever66
I tried to copy and paste your code, but with python I constantly get "unexpected indent" errors even when everything is typed perfectly.  Even if I delete and reinsert all the returns and tabs, still the same thing.  Its the one and only reason I quit trying to do anything with python.
However, make sure you have a family loaded into the project, and the family should be a Mass type (create the family using the Mass.rft template.)   I would name the family "BoxFamily", and if that doesn't work, try also creating a family type called "BoxFamily".
Anyhow, I do have one suggestion for you.  Try using the Revit Macro Editor that comes as part of Revit.
Goto the "manage" ribbon, select "Macro Manager", and create a new Module making sure to pick Python.  With a new Python Module,  Revit adds a few Python code samples that you can enable and run by changing "if False" to "if True".
Dear Cheng, attached please find the family symbol 'cube' for your reference. See if it can work.
