Pipe Pressure Loss Report,Velocity Pressure, Why is Velocity = 0 in fitting?,
reylorente1
Message 1 of 1
reylorente1
I am looking at the results in the Pipe Pressure Loss Report, and I see that in the row of the fittings, velocity pressure has a value. However, the velocity puts 0, so if the velocity pressure, depends on the velocity, why do they put zero?.
How do you find velocity pressure?
(Estoy mirando los resultados en el Pipe Pressure Loss Report, y veo que, en la fila de los fitting, velocity pressure [Presion Dinámica] tiene un valor. Sin embargo, la velocidad pone 0 entonces si la velocity pressure [Presion Dinámica}, depende de la velocidad, por que ponen cero?.
¿Como lo hallan la velocity pressure [Presion Dinámica}? )
Make an example with the original template (Plumbing-Default_Metric)
Here I share the images:
I already asked this question at Revit Forum MEP, and I was recommended to use other software, but I would like to know why?
(Ya esta pregunta la hice en el Revit Forum MEP, y me recomendaron usar otro software, pero me gustaría saber por qué?)
Replies (0)
